原帖由 racingpht 于 2020-2-6 21:09 发表 ![](http://www.tslt.tech/bbs/images/common/back.gif)
估计你没看懂,Atc在这三个箱子里是最弱的,那个帖子贴主最喜欢的是真力(连头像都是),其次是kii
看了你的房间的图,你只能选真力+glm或者kii,但我建议kii,也可以考虑me-geithain带k的型号。 ...
R版明鉴:#176楼 是他的总结贴,他的Kii高音单元有问题,最先被送回去了,他主力比较独眼龙和20
After another two weeks with 8351 & ATC20 placed on a 2 meter equilateral triangle with my ears, now I can confirm I like ATC20 more.
又经过了两周对于8351和ATC20的比较。两对音箱都被放置在对于我耳朵距离2米的等边三角形位置上,现在我可以确认我更喜欢ATC20.
8351 + GLM callibration vs ATC SCM20ASL + Sonarworks calibration
8351加GLM校准 vs SCM20ASL 加Sonaworks校准
LF: ATC has less quantity but better clarity, 8351 is boomy and kind of muddy, maybe because of my room, but since I changed many positions with 8351 before so at least 8351 is hard to get LF right in typical domestic rooms.
低频:ATC低频量上较少,但是更清晰。也许是因为我房间的问题8351有点拖泥带水的轰声。但是我就8351的摆位已经进行了多次的调整,也许在一般家庭的环境里面,8351的低频就是很难搞好。
Low Mids: ATC is much tighter, just sounds right.
中低频:ATC更加紧致,恰到好处
Mids: ATC has better vocals, sounds more natural, more full bodied.
中频:ATC有更好的人声,更加自然和体型完满
Highs: I cant hear the difference. Both very good.
(and remember ATC20ASL is much cheaper than 8351)
高频:我听不出来区别,两个都非常好。(需要知道ATC20ASL比8351便宜很多)
So I decide to use all ATC for my HT.
所以我已经决定使用ATC作为我全套的影院配置
I also ordered a bag end ISUB18, maybe pairing it with ATC/8351 would generate more interesting find-outs, we'll see.
我也订购了一台bagend ISUB18,或许配合ATC或者8351会有什么有趣的发现,我们等着瞧
Another tip: Sonarworks is a must have if your FR is not flat, or like me you use a sealed monitor like ATC20, which benefit a LOT from Sonarworks LF boosting.
另外一个窍门:如果你的频响曲线不平,你一定要用sonaworks。特别是用ATC20这样的封闭箱子,sonarworks会帮助提升低频很多。
I also would demo Trinnov ST2 in this room for some time later(thanks to my Kii THREE dealer) to see if it would be worth the extra money.
Kii的代理也将会在我的房间里帮我试听Trinnoy ST2,我会看看值不值得花更多的钱。
上面就是翻译了,后面的帖子就是这个楼主怎么开心的用ATC 20, ATC 12 和炮组装家庭影院了。。。
